[SOLVED]Problems with PSX Rearmed.
Sigurd
I'm having some issues with PCSXRearmed r14 after updating to Super Zaxxon beta 5.
Before i did the upgrade i could run nearly all PS 1 games without problems, now most of them seem laggy and Tekken 3 is both laggy and is sporting many graphical errors.
The Graphical Errors:
[image removed]
I tried resetting to default settings.
I am not running any overclock on it.
Has anyone else had this problems? or perhaps something similar
It seems other people having problems with PCSX Rearmed is getting freezes and crashes :/
PS: I didn't know whether to put this in the PSX rearmed thread or in the Super Zaxxon beta 5 thread. Feel free to move it.
- Sigurd
Sigurd
Hmm, I'm afraid I don't know how to use another kernel? :/ It's currently using 3.2. What other Kernel could I try and how?
kirkanoss
i have beta 5 boot 3.2 running
pan's clock set 750 default max opp 5
pcsx rearmed r14
frameskip auto
region auto
cpu clock 630
bio 7001
gpu plug. builtin or gpupcsx4all works for me
spu builtin
gpupcsx4all options all off, but disable lighting on
also game is a bin/cue tekken 3 runs fine 46ish fps music is alittle slow/laggy
hope some of this info helps
ps also play alot of ff7,capcom vs marvel,gt2, all the tony hawks,mk trilogy, x-men vs street fighter with same settings
Sigurd
pcsx rearmed r14
frameskip auto
region auto
cpu clock 630
bio 7001
spu builtin
Hooray! This solved it. I forgot i had been messing around with some settings in order to try and get Revolt to work. I was using the GLES plugin. I swapped it for the builtin and it ws running smoothly again. :)
