Does Not Work With Battery.
Jdriele
My gp2x does not work anymore with my battery. I done lot of test with other battery same result
But it's work with an adaptator !!!! What's going wrong ?
Check your battery contacts. Sometimes they get flattened and won't touch both sides of the battery. You'll just need to carefully pry them out a bit, a millimeter or less. Be careful!
Adaptator plug was locked (as an interuptor).
Severals pluging / unpluging solved the problem.
