So I imagine everyone here has suffered from "battery fade" on some piece of tech - you know, the way your laptop battery capacity is cut half every 6-12 months.  This is a relatively well understood phenomena, at least for lithium ion batteries, and is accelerated by heat and extremes of charge level - hence the Prius being programmed to keep the battery between 40% and 60% charged - you "waste" 80% of your capacity, but the battery lasts much longer.
So what I'm thinking is, is there some way to prevent the pandora from charging all the way - i.e. an automatic cutoff circuit of some sort? It's easy enough to set the lower limit in software (critical hibernation level = 20% or something), but I'm not so sure about the upper limit. Any ideas?
