tim0391
hi guys well i have a problem with my monitor and i wondered if anyone could help me.
well what the problem is when i removed the power from the monitor to plug it into another computer its gone horribly purple :blink: . At first i thought it had lost its settings and needed to be reset and after doing so it hasnt changed.
so far i have played with the color settings nothing
set to factory nothing
turned everything off and prayed nothing
well im stumped i wonder if its completely knackered
anyone got any ideas
thanks anyway
tim
p.s will post pics later on
EDIT:
its a fooking miricle!!!! :lol: as soon as i turn my cam on and plug it in and start to look at the screen it turns back to normal its bizzare i was thinking there is no point in taking pictures cos you cant tell the differance between good and bad
HA
thanks anyway
tim
EDIT:
HA
