USB hub and USB control
MarTinazzI
Brazil
hello
Guys I have a little problem with my USB, I can not connect my usb hub or usb my control and some pendriver it does not recognize.
Can someone give me a light.
Thank you.
MarTinazzI
Hallo
Have you enabled USB Host? I think its disabled by default, Another thing is the hub 2.0 or above as 1.1 devices will crash the port until you reboot it.
if its a 2.0 hub and host is enabled could you give us the output of lsusb from the terminal.
Some Hubs you need to plug in the device into the hub before plugging into the Pandora.. Otherwise it will hang the USB Kernel module.
thx guys,
working fine.
Now i need know how to configure USB gamepad to snes. =)
MarTinazzI
