Suilu/IP
- Joined
- Mar 26, 2012
- Messages
- 10
- Age
- 37
Ive been having some problems with my battery charge meter. Today it showed 11% left in the battery and then suddenly dropped to 5% which came with an alerting dialog of automatic shut-down. I canceled it and though I had (as the meter shower 20 min till the full discharge occurs) however right after that the battery charge meter showed ''00:00 with 00%'' left and I quickly connected it to the mains charger, but system suddenly shut it self off (without a proper OS shutdown).
What would be the best solution to remedy this inaccurate battery charge meter problem so I don't have to risk loosing all my data or worse...? I want to find a way to reset the battery or the batter charge meter (as I read it does it every time I re-insert the battery), but does it mean i have to have have already considerably charged battery or battery with little charge or... how?
Once Ive tried to re-set the charger meter that way with battery which had ''100% charged'' status and after the reboot it showed ''75% charged'' status... What is really a problem here?
Btw, I am using Super Zaxxon Beta 2
Thanks in advance.
Thanks in advance.
